ip (wlan-config-mode)
- Access Points:
AP3000/X, AP5010, AP310i/e, AP410i/e, AP505i, AP510i, AP510e, AP560i, AP7602, AP7612, AP7622, AP7632,
AP7662, AP8163, AP8533.
- Service Platforms:
Syntax
ip [arp|dhcp]
ip arp [header-mismatch-validation|trust]
ip dhcp trust
Parameters
ip arp |
Configures the IP settings for ARP packets |
header-mismatch-validation |
Verifies mismatch of source MAC address in the ARP and Ethernet headers.
This option is enabled by default. |
trust |
Sets ARP responses as trusted for a WLAN/range. This option is disabled
by default. |
ip dhcp trust
ip dhcp |
Configures the IP settings for DHCP packets |
trust |
Sets DHCP responses as trusted for a WLAN/range. This option is disabled
by default. |
nx9500-6C8809(config-wlan-test)#ip dhcp trust
nx9500-6C8809(config-wlan-test)#show context
wlan test
description TestWLAN
ssid test
bridging-mode local
encryption-type tkip-ccmp
authentication-type eap
accounting syslog host 172.16.10.4 port 2
data-rates 2.4GHz gn
client-load-balancing probe-req-intvl 5ghz 5
client-load-balancing band-discovery-intvl 2
captive-portal-enforcement fall-back
ip dhcp trust
acl exceed-rate wireless-client-denied-traffic 20 disassociate
enforce-dhcp
broadcast-dhcp validate-offer
http-analyze controller
Related Commands
no (wlan-config-mode) |
Resets IP ARP or DHCP trust parameters to default. ARP trust is
disabled, ARP mismatch verification is enabled, or DHCP trust is
disabled. |
